help needed ds 650
Old Nov 1, 2004 | 07:16 AM
Bearsy's Avatar
Default help needed ds 650
ok have destroyed the rear axle bearings, was 15 km down the coast when happened and had to get back so its lookin pretty sad now. how do you remove the rear axle, from the left or right side and is the right side stub nut left or righthand thread, anyway back to the centre of the axle, tried to remove that little circlip thingy on both sides [ the one near the sprocket and the one near the disc ]but wont come out. any assistance would be appreciated thanx.
Old Nov 1, 2004 | 08:09 PM
Bearsy's Avatar
come on guys need help please?
Old Nov 1, 2004 | 08:23 PM
DCryder's Avatar
The hub nuts are right hand threads. Then the aluminum nut next to the brake disk (loosen pinch bolt first) needs to be TIGHTENED enough to remove the clip, then turn counterclockwise and remove. Remove brake calipers, pull disk/hub off and axle should pull out of the right side. (Chain has to be taken off too.)
If I missed anything feel free to chime in.............anybody???
Old Nov 1, 2004 | 10:41 PM
DuneMe's Avatar
Really watch it riding on bad bearings. You may have damaged your axel (this is more for future readers, obviously nothing you can do about it now.)
Key item:
1. The axel nut is on the left side of the bearing carrier. You need to loosen (remove) the little screw on the nut and then you TIGHTEN it on the axel - towards the bearing carrier. Now, you can remove the pin that the axel nut is tightened against. Careful not to bend it. Remove it to the left side of the axel.
Sjrpp
Jul 5, 2015 09:04 PM
traumajunkie
Jul 5, 2015 03:03 PM
tweeder
Jul 5, 2015 01:57 PM
Mphillips
Jul 2, 2015 07:20 PM
