LEAK
Old Nov 1, 2004 | 03:42 PM
FFCHADBO's Avatar
Default LEAK
Okay my 2001 DS is leaking gas and it's coming from a black hose that's located on the bottom of the carb. The hose just runs down not connected to anything.
Is that hose suppose to be connected to some thing??
I know I need a service manual.
Thanks for your help
Old Nov 1, 2004 | 03:56 PM
Prozack's Avatar
Default LEAK
This is the drain / overflow tube for the bowl. does it just dribble a little or does it constantly flow out as it sits there ?
Old Nov 1, 2004 | 04:07 PM
FFCHADBO's Avatar
Default LEAK
It's leaking quite a bit the gas smell takes over my garage.
The hose dose have a little split in the side of it also.
Thanks
Old Nov 1, 2004 | 04:38 PM
R00ST's Avatar
Default LEAK
maybe the screw came loose and is letting gas flow out of the bowl?
check to see if that little screw at the top of the tube is loose or if its tight.
exmotocrosser
Sep 13, 2019 06:12 AM
1ArmBandit
55
Oct 14, 2015 09:03 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
bvolks
Sep 13, 2015 12:57 PM
