Stroking the DS....
Old Dec 6, 2004 | 12:32 AM
Entomber's Avatar
Default Stroking the DS....
Anyone here have thiers stroked? If so how much of a difference did it make? Is there anyway to get low end arm ripping torque out of this beast? My DS feels pretty lunge forward like, but I want a little (or a lot) more.
Old Dec 6, 2004 | 12:52 AM
sandbomber's Avatar
For me the ET was the same but the low end was out of this world. Cant explain how much fun it is pulling a steep dune not much over a idle!!!
Old Dec 6, 2004 | 01:19 AM
busmechanic's Avatar
torq is funner than HP[img]i/expressions/face-icon-small-smile.gif[/img] thats my explaination
Old Dec 6, 2004 | 01:26 AM
huskerjim's Avatar
First of all with that 46hv thats your problem with low end torque, I lost mine as well than when I put the factory carb back on......
BAM it was all there and more. You outta check out some other carbs you might find one that a little nicer on being generous on torque. I am if I find anything will let you know, but the carb you have has pleanty of top end!
Old Dec 6, 2004 | 01:38 AM
sandbomber's Avatar
I ran both the 720 and the 770 stroked side by side for weeks with everything else the same. Duel fcrs on both. Dont ask me why but the 720 was faster in the 100 yards but the 770 was much more fun to ride.
Old Dec 6, 2004 | 01:59 AM
DuneMe's Avatar
Went from a Stage III - 11:1 piston set-up to a 680 (102mm bore) with the 11:1. Then to the 760 with the 12:1 set-up.
The 760 is an amazing duner. There's no comparison with the difference of power.
I think Falicon and TVI offer crank options for your TVI Sleeved Cylinder. I would suggest sticking with Gary. He's done well for you with the 720 and he's the one that put together the kit.
Down side. . . strokers are expensive and they require splitting the cases.
Old Dec 6, 2004 | 02:03 AM
DuneMe's Avatar
[quote]
Originally posted by: sandbomber
What's the bore and stroke on that 840 you're building? Sounds like that will be a fun one!
Are you going to put Nitrous to it and drag it or just set it up for duning?
Old Dec 6, 2004 | 03:18 AM
Entomber's Avatar
DuneMe,
My 720 is leaking coolant. I'm looking into an option of sending it to MRHP and have him do the whole works. How do you like your 760. I saw Wayne's run at Silver Lake in 2003 and he was wheeling it down the raceway. He also had a base model 760.
Husker,
Actually the HV46 woke up my bike ALL THE WAY AROUND. I love this carb. I just need to dial it in a bit more. Has a slight bog which I'm sure I can get rid of. Since I put that carb on and fiddled with the Clutch my DS pull strong now, but I would like a Raptor like ease of front end off the ground at will effect.
Old Dec 6, 2004 | 10:52 AM
shmee's Avatar
duneme i thought stroking was only a grand. and a big bore was two g's.? so you dont gain a lot more hp just torque.?.?
Old Dec 6, 2004 | 11:54 AM
Martianman's Avatar
I'm pretty sure the Bomb(forum member on here)has a stroker on one of his DS's.I know he's a Pami and Ron Woods dealer,heis a straight up guy to deal with.
