radiator fluid
Old Dec 6, 2004 | 04:16 PM
bombrider's Avatar
Default radiator fluid
hey guys, i live in a prety warm area, never go's under 10 deg celcius, can i not use any untifreez in my coolant?
thanks guys
Old Dec 6, 2004 | 05:22 PM
DuneMe's Avatar
Antifreeze does two things. . . lowers the freezing temperature and has corrosion inhibitors.
You don't need the first one since your quad isn't stored in cold climate. I don't think there is any steel in the quad so, I wouldn't worry about rust. If you have a sleeved jug then you need something to prevent corrosion but, not with aluminum (I don't think).
Oh, the third thing Antivreeze (Glycol) does. . . reduces the efficiency of the heat exchanger (radiator).
Engine Ice MAY have the corrosion inhibitors you need. Not sure.
Old Dec 6, 2004 | 05:56 PM
Billboard's Avatar
Don't forget anti-freeze also lubes the water pump.
Old Dec 6, 2004 | 06:01 PM
learnenem's Avatar
engine ice or water wetter. any prodcut that takes the oxygen out of water to help create lower running temps
Old Dec 6, 2004 | 06:17 PM
BOMBSAINT's Avatar
trust me ... ... even aluminum is subject to corosion. use coolant. aluminum will pit and scale from the contaminates and minerals in water. the coolant helps to keep that to a minimum. if you can afford a ds you can afford six or seven bucks for a jug of coolant that will last about three complete fluid changes. jmo [img]i/expressions/face-icon-small-wink.gif[/img]
Old Dec 6, 2004 | 06:46 PM
learnenem's Avatar
how often should you change your coolant in a DS?[img]i/expressions/face-icon-small-confused.gif[/img]
Old Dec 6, 2004 | 07:03 PM
BOMBSAINT's Avatar
I change mine once a season . maybe twice if i do alot of riding. by the way get a jug of distilled water from the grocery store for a buck and use it with coolant. it is free of minerals. that is what engine ice uses with its chemicals. engine ice is pre-mixed and that is what it is mixed with.
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
panicmanic
Sep 28, 2015 12:59 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
Logan Collins
Sep 5, 2015 08:03 PM
