Carb CFM
Old Dec 6, 2004 | 09:15 PM
Oldmanracing's Avatar
Default Carb CFM
Has anyone flow tested the stock carb to see how many cfm it could flow?
How do you calculate carb size requirements? What size for HP range
Old Jan 4, 2005 | 08:50 PM
Default Carb CFM
Just wanted to see if anybody could reply to my question.
Old Jan 4, 2005 | 09:53 PM
DuneMe's Avatar
Default Carb CFM
You may be able to find it Here!
I know Scooby has done the calculations for people before.
Old Jan 5, 2005 | 05:15 PM
44MAG's Avatar
Default Carb CFM
Mikuni
Any one know why they don’t have any information on the bsr carbs on there site?
Old Jan 5, 2005 | 09:18 PM
Default Carb CFM
It appears looking at the Mikuni site that the DS 42mm CV carb flows at the rate of a 40mm flatside.
This would be about 200 at 12 inches of water
200 X 1.5 = 300cfm at 28 inches of water(roughly)
If the carb flows 300 and is usually 20% larger than head flow requirements,
then this carb should be adequate when used with heads that flow 240cfm(220stock)
to generate in the 55 to 60 horsepower.
Has anyone just had their heads slightly ported/cleaned up, installed a high compression piston(11to1),
stock cam and dyno'd the results?
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
