ac pump tm45
Old Dec 6, 2004 | 10:32 PM
okds650's Avatar
Default ac pump tm45
I bought a tm45 carb that has no acell pump,is it possible to put one on ?and if so where do you get one? is that a knock out where the pump rod goes?
Old Dec 6, 2004 | 11:16 PM
sam's Avatar
sam
from what I heard yes. contact Ron Wood Racing at rotax.net get the # 50 nozzel aim it at the needle when you install. set it up for a short duration squirt. about 0-1/4 throttle
If you have any other questions just ask
Sam
Old Dec 6, 2004 | 11:31 PM
OregonDunePatrol's Avatar
what he said.... The pump works good - just follow the instructions to the tee
Old Dec 7, 2004 | 12:06 AM
okds650's Avatar
THANKS I'll contact him
Old Dec 7, 2004 | 09:03 AM
eRo's Avatar
eRo
make sure u have the spring and plunger too, it will be in your carb float bowl body.
Old Dec 7, 2004 | 01:30 PM
JMAC650's Avatar
PM hightower. He seems to have the setup for the TM45.
exmotocrosser
Sep 13, 2019 06:12 AM
BYC
Sep 25, 2015 02:10 PM
rockinkgin
Sep 25, 2015 01:52 PM
Sw00p
Sep 24, 2015 02:50 PM
