NEW TURBO SETUP!!!!!!
I'm not an electronics wizard or anything even close but I have to ask. Wouldn't it be easier if the second board was used for a second map - a NOS map that increased the fuel to within a very closely mapped a/f ratio margin then use the cheaper o-2 sensor that could afford more time to dial in? The second map could be triggered by the same signal that triggers the NOS solenoid. I guess that the map would have to programed for the size of the shot and reprogramed any time you change the shot but who changes the size of their shot that often? Just a thaught but of course if I thaught of this I'm sure Kelly thaught of it as well. [img]i/expressions/face-icon-small-confused.gif[/img]
The goal is to have a fuel delivery system that automatically corrects itself to a perfect ratio. This makes it easier on everyone. Kelly wants to set up a system that bolts on to any bike and runs great. He does not want to have to program a second board specific to different pistons, big bores etc..... the second board makes the system control the ratio perfectly and instantly (nearly). NOS, big bore, higher compression, Larger valves, It won't matter. It will get the correct amount of fuel.
justin
justin
#15
you drive that grand canyon size gap every day.
I have no doubt he is telling the truth about the workings of it.
#16
Originally posted by: crackerJack
I know the O2 sensor is more money by 2-400$
justin
justin
Being able to run a dry shot of nos could be fun! I have no plans on running NOS with my 14:1 compression, but Eric says he runs nos on his 16:1 with no problems.
#17
I am sure the sensor is at least 200$.(I talked to him this morning) I don't know why it is so much. I don't know how he will handle updating all existing customers. I think he thought that all the existing sensors would be enough for the system. It is only recently that he found a different more expensive O2 sensor would be. He said he rode a bike that he felt was set up perfectly on the mapping we now use and then when he changed it over it made a huge difference. He said the difference was incredible. Maybee there is more power in that 16/1 sandaholic.
justin
justin
#18
[img]i/expressions/face-icon-small-smile.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img][img]i/expressions/face-icon-small-sad.gif[/img][img]i/expressions/face-icon-small-blush.gif[/img][img]i/expressions/face-icon-small-disgusted.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-mad.gif[/img][img]i/expressions/face-icon-small-shocked.gif[/img][img]i/expressions/face-icon-small-tongue.gif[/img][img]i/expressions/face-icon-small-cool.gif[/img][img]i/expressions/face-icon-small-frown.gif[/img][img]i/expressions/face-icon-small-confused.gif[/img]
#19
Logan Collins
09-05-2015 08:03 PM
