OK Guys the cover is off. But what is up with the Barnett springs ? Please help.
Old Dec 25, 2004 | 07:58 PM
Mrneg9's Avatar
Default OK Guys the cover is off. But what is up with the Barnett springs ? Please help.
Well the cover is off and I cant believe no fluids came out other than a tiny bit of anti freeze. Thanks for the( Tilting on side tip).
Now I took the Barnett springs out of the package and they seem to be the same in length and stiffness. They might even be more giving than the stock springs.
I replaced the springs in my street bike( Honda VTX C model 1800 cc) with Barnett springs and they were a little longer.
I don't want to replace the springs and have the same results as having the stock ones as it is a waste of time. What kind of springs do you guys suggest and where can I buy them?
The only thing that sucks now is I will have to wait to put the bike back together. Thanks, D
Old Dec 25, 2004 | 08:07 PM
shmee's Avatar
we put in a barnett kit with r.wood 60% springs, would not shift worth a darn. put the barnetts in that came with the kit, no problems. shifts fine now. use the barnetts it will be ok. pluss i think they are a diff lenght than stk ones??
Old Dec 25, 2004 | 08:53 PM
thebigshow's Avatar
mrneg9, it kinda depends on how big a guy u are...if u are 300 plus i would order some stiffer springs form rwr or tvi..i tried the barnett springs and they began to slip after three rides...but that can also be contributed to the oil i was running... even after slipping the clutch badly with the new barnett clutch..i still have that clutch in and it hasnt slipped once since i put in the spings i got from TVI...
Old Dec 25, 2004 | 09:06 PM
Mrneg9's Avatar
I'm 6'7" 305 lbs. The Barnett springs are the exact same length and stiffness as stock. I have never heard of rwr or tvi. Do you have an address ? Thanks, D
Old Dec 25, 2004 | 09:41 PM
thebigshow's Avatar
try this out....http://web.dsworks.net/430839.htm
im not sure on the Ron woods ...i think its ronwoodsracing.com
Old Dec 25, 2004 | 09:44 PM
thebigshow's Avatar
sorry i was wrong...it is www.rotax.net
Old Dec 26, 2004 | 01:55 AM
darkspiritbiker's Avatar
been through this one!!! Barnetts are only 13% stiffer per Tech's at Barnett. kit#mt14-6 I think from alba.
Go with the 60%woods from dunes. best $$. the pull not very noticible compared to the performance gain.. seems like most here agree. woods or pami.
Old Dec 26, 2004 | 02:13 AM
JMAC650's Avatar
60% woods for sure. I put them in all 3 of my DS's and my buddy's and the work great.
Old Dec 27, 2004 | 04:57 PM
2BIG2BFAST's Avatar
Im 6 ft 3 about 335 just installed the barnett clutch and springs. I have about 10 hours on them and no slippage in river riding without paddels. What im worried about is when i get to the dunes with the paddels on. The only problem so far is getting it into neutral. Im not sure but doesnt rw make a 40% spring? You might want to check into that.
Old Dec 27, 2004 | 08:25 PM
Mrneg9's Avatar
Hey guys thanks for the info. I ordered the Ron Wood 60% springs today. I should have them Thursday.
2x_lung
1) Engine problems..
48
May 24, 2023 05:22 AM
Hankey Pankey
26
Oct 18, 2020 03:50 PM
robj
Jun 15, 2015 08:45 PM
generalpops
Jun 5, 2015 08:23 PM
OLDSTER
Jan 9, 2001 10:13 PM
