hard starting
Old Dec 26, 2004 | 10:20 PM
650pete's Avatar
Default hard starting
Hey there everybody got a 03 ds650 that doesn't want to start easy. When im at the dunes starts great even when it is 30 degess but when I get home around 2000 feet elevation very hard to start and keep runnin. once its all warmed up runs like the raped ape it is. I just adjusted the valves about 4-5 months ago and got them into spec. could they be out of adjustment already?? or is it in the carb maybe too lean or something?? I am not to familiar with tuning the carb on bikes any help would be great. thanks
Old Dec 26, 2004 | 11:06 PM
busmechanic's Avatar
could be a little lean. do you know what your carb settings are now? is it still bone stock? mine was a little hard to start when it was stock and a little colder. now that it is jetted and adjusted it starts easily. you might need to adjust fuel mix screw and/or try a step or 2 larger pilot jet.
Old Dec 27, 2004 | 12:00 AM
650pete's Avatar
not sure on the carb settings put a jet kit in it think 165 jet not sure have to dig into it. I have a k&n filter also where should my clip on my needle be?? I have it in the bottom notch now. also where should the fuel mix screw be?? how many turns out should i have it
Old Dec 27, 2004 | 02:44 PM
165 is a stock main jet. is your exhaust stock? I have moded endcap. I run dynojets and needle. if you are running mikuni's it will be a whole different ball game. my mix screw is out 3.5 turns. screw it in first, to see where you have it set now. count the turns, and just bottom it out. no need to tighten it. I would geuss that others on here have theres anywhere from 2.5 to 5 turns out. I also use the stock pilot jet. but that might help a little in starting to go bigger there.
MikeyBoyesq
Nov 27, 2020 02:44 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
chinkapin
Jul 14, 2016 06:58 AM
Ty Speece
Jul 2, 2015 04:59 PM
1000gade
May 27, 2015 12:37 PM
