QwikSilver Carb
Old Sep 13, 2000 | 04:09 PM
tdporter's Avatar
Edelbrock is developing a QuikSilver kit for the DS650. It is suppose to be available in about a month. Hopefully we can get it with the pumper series carb.
For those of you that have never heard of these carbs, they are great. You can read about them at: http://www.edelbrock.com/motorcycle/index.html
Old Sep 13, 2000 | 05:38 PM
tdporter's Avatar
Yes! It will be a pumper series. I can't wait.
Old Sep 13, 2000 | 09:55 PM
tdporter's Avatar
By kit, they mean taking an existing pumper series, making the cables, boots, etc. that fit a DS. And of course, figuring out the best jettings for the DS. Yes, they are going to have dyno charts for us.
I didn't ask about a dual carb setup, I thought I read in another posting that there wasn't enough room for dual carbs on the DS.
I am guessing they will use one of their 40mm ones. Not real sure, since their size isn't a straight comparison to a Mikuni.
One their site, they say a 38mm will flow 10% more than a 40mm Mikuni. So, I figure a 38mm or 40mm from them would be close. This is probably one reason they get more HP, the smaller diameter = increased velocity thru the carb.
Old Sep 14, 2000 | 03:09 PM
tdporter's Avatar
A dual qwiksilver carb may be possible. Edelbrock said they were going to get the single carb kit out first, then look into a dual kit. They said from looking at the DS, it appears there is enough room for dual qwiksilvers. Cool.
Old Sep 19, 2000 | 02:22 PM
tdporter's Avatar
The complete kit will cost about $470. This is for a "electroless nickel finish". That is the only finish the carb comes in.
Also, he said dual's were out. Not enough room between the frame rails.
Old Sep 22, 2000 | 12:43 PM
tdporter's Avatar
They are doing testing today. Suppose to have some numbers next week. Hopefully some dyno charts.
Old Sep 22, 2000 | 01:26 PM
CRTLeech's Avatar
$470! That's about $100-200 more than the same carb for other models!
Old Sep 23, 2000 | 09:17 AM
tdporter's Avatar
What would the advantage of duals really give us?
If it was a 2 cylinder, I can see duals really helping, but I don't know for a single cylinder.
Old Sep 24, 2000 | 12:25 AM
JamesDS650's Avatar
Size:
Other carbs need to be larger to flow the same amount as a QwikSilver. However, the larger the opening, the slower the velocity, causing slow acceleration. A 38mm QwikSilver outflows a stock 40mm carb by 10%. quoted from edelbrock's site
Old Oct 2, 2000 | 05:32 PM
tdporter's Avatar
What are you going to order?
A little more info on the QuikSilver. They have tested the 38mm x 40mm. (These are not round like other carbs, they are oval).
This carb only produced 2hp increase, and 3lb torque over stock. It did increase throttle response a lot, turning their DS into a wheelie monster.
They are now working on the next size larger, 40mm x 42mm(I think).
