I got one! - Finally
Originally posted by: sam
cheap mods.
1) 15t front sprocket rocky mt.atv $15
2). MR. HP end cap around $100 or mod quad around $50 , there is one selling on ebay to or make your self (FREE)!.
3) A CDI Box Procom around $100, (But ive heard up and down results on this box)
4) IMHO w/ the stock carb leave the lid on unless your riding in high elevation. This topic is hot so if you want further info do a search on airbox.
cheap mods.
I did hours of researching old posts this weekend (even during the superbowl). What I finally ended up doing was ordering the MOD "Kit" from on-dunes; you know, the end cap, K&N w/outwear, and additional main jet, nice pkg was in stock and reasonably priced. Then I ordered some sand star fronts and hauler rears from Rocky Mtn. I'm not doing any gearing changes until after I ride it first.
The other thing I did yesterday was do my traditional "once over" which entails going over everything with a fine tooth comb i.e. checking bolt torques etc. MAN, WHAT DO FRENCH CANADIANS HAVE AGAINST TIGHTENING THINGS DOWN???? I'm used to Japanese stuff where I'd find an oddball thing here or there to tighten down an extra turn or something but this DS was unreal. Easily 90% of everthing I touched wasn't close to being snug. Even every zerk on the front end needed 3-4 turns to be screwed in all the way. I'm glad I didn't just buy it and head straight out for a serious weekend of riding. No big deal but I still cant believe how loose everything was.
Originally posted by: Rich807
Sam,
cheap mods.
cheap mods.
#15
hmmm thats wierd, when i took mine apart after the accident mine was the opposite, everything was really tight and loctited,
When I bought mine everything was loose too. The Frenchy's don't believe in tightening things.
#16
I tell ya it was bad. The tank bolts were barely finger tight, I already mentioned zerks. One thing I will say is that the swingarm pivot, motor mounts, shocks and wheels were tight at least.
You know what else was weird to me is having to use 2 wrenches to tighten things up i.e. "loose" nuts on the back of everything vs. the japanese way of welding nuts to the back of mounting points. I suppose it could have it's advantages but there certainly is a culture shock switching over to something that's not designed/put together in the orient.
#17
