Flowed intake problems
Old Feb 9, 2005 | 01:31 AM
mystereid's Avatar
It's official, I've been duning for over 30 years.
Default Flowed intake problems
Freez, it is possible, I spent alot of time getting my intake rubber perfect, if I recall correctly there is sort of an o-ring cast into the rubber to mate to the carb and intake. I believe I had to shave off half of that to let the boot slide closer to the carb and intake. You still retain some of the ring for a seal and to help keep the carb from coming loose. Don't forget to port match your exhaust, my gasket impeded flow. Good luck, I hope this helps.
TheHood
Aug 8, 2015 05:49 PM
JoAnnS
Jul 23, 2015 02:18 PM
Unzzy66
Jul 11, 2015 10:01 PM
cSchwartz
Jul 9, 2015 02:43 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
