dual Valve spings
dual Valve spings
I just went to the Ron Wood valve springs for Pami Cams. I have had bad luck with springs (Pami) - The first set didn't quite make it a year and the second set didn't quite make a year either. Not sure who makes the valve springs for Pami.
I am planning (no promises here [img]i/expressions/face-icon-small-wink.gif[/img] ) to keep my revs under control. That may be what eventually led to the failure. But, after two sets lasting just under a year each, I've decided it is time to try another kind. In my mind, Ron Wood has some of the highest quality and most reliable stuff on the market so, I decided on theirs. I'm not sure who makes the valve springs for Ron Wood.
Kibblewhite makes valve springs too.
Most builders go with one of the above. Does anyone know another source? Anyone know where Ron Wood gets their valve springs?
Also, you may need different retainers if you switch valve spring manufacturers.
09-30-2015 01:37 AM
