Valve Adjustment
Old Sep 20, 2000 | 05:24 AM
OregonDS's Avatar
I finally got around to checking the valve clearance they all where at .005 (that is as close to the middle of the specs that I have a feeler gauge for) But one was a little tight the left intake valve but I have no clue as to how you change the clearance any help would be apprecated. I'm a diesel mechanic but that sucker looks nothing like a Cat or a Cummins on the inside. Thanks for the paddle help and Scooby would you be intrested in selling yours once you get the 22's.
Old Sep 20, 2000 | 02:25 PM
CRTLeech's Avatar
You change the shims. Don't ask me how, but that is what I was told by the local dealer. Pretty crappy system if you ask me, but I have been told that once you adjust them for the initial break in, they are pretty consistant and long lasting.
Good luck,
CRT_Leech
Old Sep 20, 2000 | 06:39 PM
Ang's Avatar
Ang
If a .004 will fit then it is ok. The tappet is actually a cover that sits on the spring and the shims are between the tappets and the retainer.
It is a very common system for overhead cams and stays truer than set screw style adjusters.
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Brandon400
Sep 5, 2015 08:44 PM
Jason Richards
Sep 4, 2015 06:17 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
