first ride, stage one
Old Feb 20, 2005 | 11:11 AM
crazypainter's Avatar
Default first ride, stage one
Duneme yes its all tuned on the dyno. 38 runs worth . Woods ported intake. KN with snorkle, no air box, TM45, woods cdi. I'm thinking she's breathing but the stock pipe aint that bad with an end cap. In a few weeks I'll run my old racing buddy and see how it really runs, but he got his dyno tuned and picked up a little extra too[img]i/expressions/face-icon-small-smile.gif[/img] It will probably still be really close, but thats half the fun!!
Old Feb 20, 2005 | 11:41 AM
Budman650's Avatar
Other than the stage 1, it's stock. I even played with the 15 tooth sprocket for the dunes, but it really hurt the top end. I normally run at about 450 feet elevation.
Old Feb 21, 2005 | 01:40 AM
NickDS650's Avatar
That just doesnt sound right, a full stage 1 kit and u only gained 1.7 HP and u lost torque, torque should be a huge gain with the carb and exhaust? Doesnt make sense since u said it feels snappier and pulls harder? [img]i/expressions/face-icon-small-confused.gif[/img]
Old Feb 21, 2005 | 08:12 AM
RobK's Avatar
What were you max HP, and torque readings, and at what RPM's were they maxing out at, and what tires were you running while on the dyno?
Old Feb 21, 2005 | 01:34 PM
  #15
I already had everything but pipe on it, the only difference was the pipe. Tires, gearing, carb, intake, cdi, were all the same. the 1.7 is the difference between my stock pipe with my modded end cap and the RWR full exhaust. the graph for both is on my pics page.
Old Feb 21, 2005 | 02:19 PM
  #16
biggerisbetter's Avatar
Makes perfect since to me really, If you look at the Graph, you will see the the Woods pipe biulds power in the mid-range and well into the upper RPM's. and the Modded endcap has a good low low end burst, but if you ride were you use the entire powerband then the Woods pipe will feels much better. and you will feel your quad is running stronger cause it is in the RPM range you ride in.
BIgger.
Old Feb 21, 2005 | 09:37 PM
  #17
thebigshow's Avatar
51.7 h.p for a stage one sounds like a pretty good number to me....the second set of lines ( im guessing is the ron woods stage 1) seems to put the power where u are going to want it, the power band is wider..
Old Feb 21, 2005 | 09:55 PM
  #18
shmee's Avatar
ya i think his bike was built on a sunday![img]i/expressions/face-icon-small-wink.gif[/img] lol
Old Feb 21, 2005 | 10:00 PM
  #19
Can't complain about the HP. numbers, I just thought I would have gained a little bit more than that over a stock pipe.
Old Feb 21, 2005 | 10:05 PM
  #20
Hey big show any chance of you comeing to Little Sahara over Easter? I'd love to see how a big bore DS runs.
