How to Fix that Seat?
Old Feb 22, 2005 | 09:01 PM
Rich807's Avatar
Default How to Fix that Seat?
Just got back from Glamis and I really liked my 1st dune weekend on the new DS with the exception of a couple things and one of them is the seat. I'm an aggressive rider that likes to sit in the "pocket" and what was driving me absolutely crazy is that the seat would pop, rattle, and move around a little bit. I must've re-attached the seat 10 times over the weekend trying to make sure I had the 2 prongs in the tracks as solid as possible but I still got a loose fitting one on the right side and the seat seems to buckle outward around the tabs on the frame every once and a while. When I took the seat off today the plastic tabs were beat up from buckling out and sliding past the metal tabs on the frame.
Thanks in advance.
Old Feb 22, 2005 | 09:25 PM
sam's Avatar
sam
I made a little tab, it hasn't done that since. PM me you email Ill send you a pic.
Old Feb 22, 2005 | 09:31 PM
Dunnycat's Avatar
I know this sounds cheezy but it worked for me.I put thouse plastic ty wrap's two on each side around the shaft between the seat and flat washer. I think the shaft is two small for the slots that are on the frame. PS some people call those thing's zip ties or wire ties.
badgerboy1
Sep 26, 2017 06:11 PM
Whitelx1
Oct 2, 2015 10:55 PM
Dunes and Dune Machines
Sep 29, 2015 09:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
wrencher82
Sep 24, 2015 03:39 PM
