Help-Is this possible?
Old Feb 26, 2005 | 08:58 PM
VEGAS650's Avatar
Default Help-Is this possible?
Is it possible to get fuel in the oil.
I have a tank at the end of my breather hose and it had gas in it.
When I drained my oil, it smelled a little like gas.
The thing was running great and the plugs look perfect.
Old Feb 26, 2005 | 10:33 PM
MongoDS's Avatar
This has happened to me before but not on my quad. It happened to me on an air compressor. The problem was that I had left the fuel on and the carb bowl overflowed and the gas ran down into the intake valves then down the cylinder past the piston and into the crankcase. Are you leaving the fuel petcock on while your DS is not in use?
Old Feb 26, 2005 | 10:41 PM
Eaglecollector's Avatar
To add to what MongoDS is saying. I don't think leaving the petcock on is gonna cause fuel to run into the bowl and overflow the bowl unless the neddle valve has stuck open because of debris. Or if your float level is set to high.
Another reason would be if for some reason someone is twisting the throttle while it sits. Ya got kids around your quads??
Old Feb 26, 2005 | 11:37 PM
VEGAS650's Avatar
Yea, Dave told me a little while ago that my float level is not correct and that it's over flowing while the bike is just sitting thetre. Because i do not just the gas off.
Also lots of people like to try out my throttle, so to speak because it's so stiff.
z4hundo
Mar 22, 2005 11:20 AM
rawze
Feb 13, 2001 02:40 PM
