carb trouble
Old Feb 26, 2005 | 11:11 PM
chiknhawk's Avatar
Default carb trouble
if you have read my attn mudnuri thread you know i have carb trouble. Well i decided to try to adjust the needle, Well when i Pulled the needle out the spring popped out, and i dropped everything. I need to know exactly how it all goes back in. I have the needle first. Then there are two small flat washers on e a little thicker than the otherand the little e clip and the small spring. I need to know the order in which they go. I am open to any advice Ive been trying to fix my problem thanks for looking, John
Old Feb 26, 2005 | 11:27 PM
2BIG2BFAST's Avatar
In my book there is the needle, then a small flat washer, then a bigger washer, then the e clip, then the small washer, then the spring.
Old Feb 26, 2005 | 11:34 PM
chiknhawk's Avatar
thanks for the info. It looks like i may have lost one of the small washers, because i only found one. Thanks for the help. Does anyone have a carb for sell? Thanks John
Old Feb 27, 2005 | 08:59 AM
Hightower's Avatar
there are 2 metal washers, and one white plastic washer.
if you lost one or more, they can be bought for pennies. Ron Wood Racing most likely has them, as well as any carb parts shop you can find on the web, shipping will be way more than their cost. if you have some bike shop sin the area, see if they have some washer assortments to thumb thru.
Can somebody out there measure the thicknesses of the 3 with a micrometer for chiknhawk, so he knows what he's looking for? I don't have a stock carb anymore.
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
