clutch is hard to shift
i took the steels out and resanded them my stock fibers were ok put them all back in order even the off set fiber put in woods 60% springs and have the shift arm at 72mm and the hand lever with about 1.5mm of play when i put it into gear it pops into gear then changing gears it is hard to shift the foot lever when its not running you can put it in gear pull the elever and you cant roll it i have tryed adusting every whitch way and still the same i even took the cable off the little lever and turned it manualy while in first gear engine not running and still the same ??????????????????
