Kill Switch?
Old Aug 23, 2005 | 05:03 PM
VEGAS650's Avatar
Default Kill Switch?
Originally posted by: SCOUNDREL
How many of you guys actually use a kill switch anyway?
I thought that it was only a requirement if you are in a closed track.
As of yet I have not seen anyone using one in the dunes......[img]i/expressions/face-icon-small-confused.gif[/img]
I use one cause I don't have any room for the key in my dash anymore.
I've combined it with a toggle switch.
Old Dec 29, 2005 | 04:01 PM
CountryJoeGlass's Avatar
Bumped this up for TwinPeaks.
Old Dec 29, 2005 | 05:23 PM
mudnuri's Avatar
I have my headlight out so it makes this a lot easier. I hope this helps.
Okay, there is the sleeve of wires coming from the on/off, headlight switch on the handlebar, going down behind the headlight. In this bunch of wires is a Black and White wire. It plugs into a solid White wire. This is the wire. I unplugged the two and plugged in the kill switch which has a pig tail splitter. Then you just need a ground. I used the Black ground that comes off the clutch lever.
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Halffast17
Sep 11, 2015 02:30 PM
alzgarvin
Sep 11, 2015 08:53 AM
Albertaboyy
Sep 9, 2015 09:51 AM
toonces
Sep 5, 2015 01:14 PM
