pami 760
Old Mar 16, 2005 | 10:12 PM
thumper650's Avatar
Default pami 760
Whats the best carb for them
Old Mar 16, 2005 | 10:19 PM
CountryJoeGlass's Avatar
Default pami 760
Is there anything wrong with the carb on it? Also the best carb for what?
Old Mar 16, 2005 | 10:26 PM
thumper650's Avatar
Default pami 760
no there is nothing wrong with it upgrading it and it is a pami 760
Old Mar 16, 2005 | 10:28 PM
SANDMAN430's Avatar
Default pami 760
what carb do you think would be the best for you? a big single that should work a little better out of the hole or two big carbs that might lack a little on the bottom but respond well up top. then there is fuel injection, but being somewhat new might have a very steep learning curve for you. now that you are thinking about that what could you do with gearing to help with the problems of each carb? and after that what cams would you think you would like to run with the riding you do, some that provide better torque down low or some that kind of lack down low but if you rev them really produce, then another question is which exhaust pipe do you think will work well for you, some are better you know, won't take many of those 100 dollar plus tickets to take your money for the carb of your choice. if you really would like to know ask the guys that have a pami ( duneme, bigwayster) this guy named jeff had pretty good luck with one, the bomb has one i believe. a friend of mine has one- and if you want to be like him he runs dual 39's. the best question is tell us what kind of riding you do, and then try and find some help. if you are just running down to the coast to ride, run whatever it comes with you will be fine. if you are wanting to run over to comp or boxcar and be in the race lane all day, get on the pami website and find there best engine set-up and pray it is enough, because it probably won't come close.
Old Mar 16, 2005 | 10:45 PM
thumper650's Avatar
Default pami 760
i do dune ridding. i like going up hills fast
Old Mar 16, 2005 | 11:32 PM
SANDMAN430's Avatar
Default pami 760
buy jeffroes other ds- not the 760 thats fast. which carb did you decide on.
Old Mar 17, 2005 | 12:02 AM
thumper650's Avatar
Default pami 760
48hv
Old Mar 17, 2005 | 12:40 AM
SANDMAN430's Avatar
Default pami 760
what carb does it come with? so what made your decision be the 48?
Old Mar 17, 2005 | 12:42 AM
thumper650's Avatar
Default pami 760
i think it is a 45 or dules but i like the 48 hv or the tm48. there just good carbs for top end and mid end
Old Mar 17, 2005 | 12:47 AM
SANDMAN430's Avatar
Default pami 760
so say it has a 45, what amount of horsepower will you gain by switching? or say you looked at rotating mass, and used the money to reduce that?
