Best Dune Shocks???
Old Jan 18, 2007 | 12:37 PM
pipelayer's Avatar
I'm a Plumbing contractor and I have some old friends that always called me Pipelayer for some reason?
Default Best Dune Shocks???
My dune edition Elka are quad rate and piggyback the only dif is no rebound adjust Elka sets it and holds a 6month return on adjustment I sent my shocks in only one time and are spot on. One week turn around.
Old Jan 18, 2007 | 01:04 PM
TPR's Avatar
TPR
The Champ
I have heard that the Fox Float Evols work well to soften up the stutter chop, don't know about on the DS though. I have run TCS and they worked real good.
Just don't be fooled into thinking that 4 springs and 5 adjusters will make a shock good. Find the one that does the best internal valving and you will be happy. I know that TCS has a long history with the DS.
That said I can't wait for Bilstein to come out with their ATV line, from what I hear about the prototypes, they will use no more than 2 springs, most cases 1 will suffice, and with their patented internal valving, true aluminum design and the need for smaller lighter springs, you will have an excellent shock, nearly as light at the Floats for a much better price than other's top shocks.
TPR
Old Jan 18, 2007 | 08:12 PM
CALDS650's Avatar
I got mine from Fox when they first came out you can Google them and find some out there. To help on the head shake get a steering stabilizer and due not get A-arms that lower the front of your quad it troughs off the weight balance
Old Jan 19, 2007 | 12:55 AM
DubaiPolaris's Avatar
916 Reaper - Pure Evil Inside!
MOTOWOZ! Simply amazing suspension. They do cost a few pennies more, but leaps and bounds better than the Elkas and Ohlins I have run.
Chris
Old Jan 19, 2007 | 01:49 AM
  #15
JMann2380's Avatar
Chris
They sure look nice and I was considering them but just not worth more than DOUBLE the cost of TCS's.
Dunes and Dune Machines
Sep 29, 2015 09:35 AM
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
bigred20653
Sep 19, 2015 02:11 PM
