i need help real bad.
Old Mar 31, 2005 | 04:43 PM
DS650power14's Avatar
Default i need help real bad.
the fuses are good. i'll redo every grounds, grind the frame and i'll check everything out with a multimeter and get back with some answers.
thanks!!
Old Mar 31, 2005 | 05:41 PM
mystereid's Avatar
It's official, I've been duning for over 30 years.
Did you try popping the fuses out and replacing them to knock corrosion off them? Simple and fast.
Old Mar 31, 2005 | 05:46 PM
96lapiscoupe's Avatar
Originally posted by: gabesworldsds650
I am a union electrician trust me .
*runs for fire extinguisher*
[img]i/expressions/face-icon-small-wink.gif[/img]
Old Mar 31, 2005 | 08:37 PM
gabesworldsds650's Avatar
ok maybe i was asking for a little backlash for pointing that out. no fire extinguisher just lot's of flash burns!!
Old Mar 31, 2005 | 09:41 PM
  #15
thanks everybody i ended up grinding 2 places on the frame to ground the motor. it started right up!
Old Apr 1, 2005 | 11:22 AM
  #16
TexasPsycho's Avatar
Noloks nasty stuff! I'm an electrician in a plant and we use it all the time too. I can't get near a tub of that stuff with out having it all over me. It really will help on your battery terinals because of the two different metals that meet.
Old Apr 1, 2005 | 01:17 PM
  #17
Dser's Avatar
Wow that's good to know. I would have thought for sure that the blots would have grounded it. Thanks for the come back. Good info.
Old Apr 1, 2005 | 05:29 PM
  #18
BOMBSAINT's Avatar
been there, done that. same thing. ground problems. never had problems with a ground on anything like the ds. it runs reverse as to most things. most electrical currents are broke on the positive side of a connection with that break being a switch. on the ds it is the opposite. the switch or breaks are in the ground line. the "hot" line of current stays unbroke. gotta love that engineering.
Old Apr 1, 2005 | 05:30 PM
  #19
BOMBSAINT's Avatar
oh yea, sorry. glad to hear ya got her unning again. electrical problems are the worst.
MooseHenden
Family ATVing Photos
Oct 5, 2015 08:14 AM
CosmoM
Sep 21, 2015 04:57 PM
essonlaker
Sep 10, 2015 01:12 PM
black_thunder
Sep 6, 2015 04:41 PM
