rear bearings grease, tips??
Old Apr 3, 2005 | 07:00 PM
eRo's Avatar
eRo
Default rear bearings grease, tips??
my ds has been recalled for rear bearings not greased properly. taking my ds back to the dealer is not a option for me. i have the shop manual, and i got the special axle nut tool. i've never packed bearings with grease, is there any tricks or tips u guys have for me??
Old Apr 3, 2005 | 08:17 PM
mudnuri's Avatar
I packed mine in ziplock baggies.
I used the same grease you'd use to lube the front end or anything with grease zerts.
Old Apr 4, 2005 | 01:28 AM
busmechanic's Avatar
you can pack them in the palm of your hand. just push/slap the edge of the bearing down in the grease until you see grease coming out the top edge. do this all the way around. then coat the outside and install. or buy a lube cage that has a zerk on it. then lube with a gun. the key is to make sure you get grease behind the rollers throughout the cage. not just the outside of the bearing.
I also noticed that bomb does not put any lube between the bearings in the carrier. I would atleast coat the inside of the carrier. it will not help lube the bearings. but it will help displace moisture.
Old Apr 4, 2005 | 07:51 AM
eRo's Avatar
eRo
u can easily pull the bearings out of the carrier?? do u have to freeze them to put them back in the carrier??
Old Apr 4, 2005 | 10:42 AM
SCOUNDREL's Avatar
Can the bearings be replaced with permanently greased bearings?
Old Apr 4, 2005 | 09:02 PM
the bearings are tapered. they will just fall out once the seal is removed. that freezing thing is only if you are replacing the bearings and races. freeze the race. heat the carrier.
Old Apr 5, 2005 | 12:08 AM
DONECRASHED's Avatar
I too use a ziploc baggie. Just fill it about 1/4 way with grease and then stick your bearing in. mush it around until you are sure that grease is properly packed into the carrier. Also I like to use a high grade boat grease in my bearings that I don't grease all that much. Grease designed for boat trailers, and outboard motors usually have teflon in them, and are extremely waterproof, "well as waterproof as and grease can be".
STLyamwar
Jul 25, 2020 04:44 AM
JohnnySplat
Aug 6, 2015 12:07 PM
toonces
Jul 28, 2015 01:58 PM
Peter_
Jul 18, 2015 07:06 AM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
