????'s about FOX FLOAT SHOCKS
Old Apr 6, 2005 | 12:31 AM
DSJOBBER's Avatar
Default ????'s about FOX FLOAT SHOCKS
Was wondering if anyone has tried them. I think I saw a post about someone using them but cant remember. Im in the market for new shocks and so far TCS's are winning.
Old Apr 6, 2005 | 03:16 AM
joshiepoo's Avatar
well jobber yer in the market for shocks huh? they look pretty keen. what happened to yer old ones? just wonderin, they're supposed to be light n stuff, the fox ones that is. what kind of shock bodies are tcs using these days? later jobberoo. ......
Old Apr 6, 2005 | 11:04 AM
thumper650's Avatar
Go with King if you want to spend so money
Old Apr 6, 2005 | 11:32 AM
BillDS650's Avatar
I have a set but due to bad luck my DS has not been out of the garage all season. John Natalie has been winning with the race version in MX
Old Apr 6, 2005 | 12:15 PM
PredFan's Avatar
I run Fox Floats on my Predator. There is no comparision to stock, and as mentioned, there a very light. Less than 3 lbs each. For trqail riding and duning, these shocks are awesome. I don't race, so I can't comment on MX applications. The adjustability is simple, pull out a small hand pump that you can easily carry with you, and adjust the pressure in 30 seconds per shock. I run mine between 50-60 PSI depending on terrain and size of jumps. Once a month you want to check them for pressure. I've had mine for about 6 months, and they have not had any signs of air leakage. There is a new fox float coming out soon called the Evo that will have additional adjustability. Overall, I am very pleased with the Floats.
Old Apr 6, 2005 | 10:59 PM
orangebomb's Avatar
how much $$$ are the fox shocks ? I see they have a new line...improvement maybe..piggyback ressys are allways nice!!
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
cboler9
Sep 24, 2015 08:35 PM
wrencher82
Sep 24, 2015 03:39 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
