striping screws
Here is an old mechanic tip for you guys!!! When you have a phillips head screw that wont come out: get a small jar of valve grinding compound from any parts store. Fill the head of the screw with the compound and insert the screwdriver in the screw and tap the end of the screwdriver lightly with a hammer, push the screwdriver down like hell and turn, works 99% of the time. The valve grinding compound takes up all the extra space in the screw head, and has grit in it to grab. I do this all the time, here and at work.. I HATE phillips screws!
The NAPA jell type is what I use, and I know what you mean, my wife has a "heat gun" for her crafts, and that thing is dang handy, boy have I got in trouble for sneaking it into the garage [img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img]
#15
You can also take a small chisle and place it on the top of the bolt off to one side, hit it and make a good groove in the head, then place the chisle back in the groove and angle the chisle so when you tap on it it will push the head counter-clockwise. This will break loose almost any bolt I have ever had a problem with. I would use an easyout as my absolute last resort. Try all other things mentioned first. Easyouts are a tough tool to master and be able to get them to work 100 percent of the time. And the first time you break off an easyout in a bolt you will be like me and probably never use them again.
#16
I recently did the same exact thing, phillips heads suck, i got 3 off wit vise grips, 1 i stripped all to hell, took the chisel like bobcat said. Just make sure u put somethin exactly correct back in the stripped screws place, i went wit allen heads but my thread patter wasnt the same, i figured that out when i snapped the head off tryin to babystep it in, now i haveat drill it out...sux
#17
when i was in the service working on helicopters we used the comet bathroom cleaner it comes in a gritty powder, dip the tip of the screw driver in water then dip it in the comet and try turning the screw head, it worked for me for 4 years
#20
thanks guys i used the vice grips and finally got them off. are there any more screws like that on the DS that i might come across again? now that i have everything done i love how the HMF sounds! it did seam to add quite a bit of power even though i didnt get to test it out other than on wet pavement from it raining all day yuck.
p.s. - busmechanic, sorry ill try to search more next time
