What's the best 14:1 piston?
Old Apr 16, 2005 | 01:06 AM
shmee's Avatar
Default What's the best 14:1 piston?
well when you get it in let us know if it will clear[img]i/expressions/face-icon-small-wink.gif[/img]. im thinking of doing the same thing.
Old Apr 16, 2005 | 03:29 AM
XR650Warrior's Avatar
Originally posted by: MrMeaner
I run a HPR 14/1 and I love it. I had a 11.5/1 Wood racing and when I changed it was a different bike. HPR's piston is really light and thats cuts down on your rotating mass and lets it rev faster
Meaner, what's the gram weight on the HPR 14:1 piston ?
Old Apr 25, 2005 | 05:03 PM
shmee's Avatar
why cant you take your stk piston and the new 14-1 to the machine shop and get the 14-1 the same weight? they do that all the time. but i heard that the boms pistons are already as light as the stk one....???...
what does the hpr piston weight??
Old Apr 25, 2005 | 06:13 PM
CountryJoeGlass's Avatar
My HPR 14:1 weighed less than a used stock piston & used ron woods piston that I had at the time.
Old Apr 25, 2005 | 06:18 PM
  #15
sandbomber's Avatar
Might want to call Eric they have a new and improved (they are always on the cutting edge)
Old Apr 25, 2005 | 06:20 PM
  #16
JMAC650's Avatar
How much horsepower do you think you would gain from a 14.1 piston and a set of cams?
Old Apr 27, 2005 | 03:01 PM
  #17
shmee's Avatar
how much power from a 11.5 to a 14-1????? some one shur knows? mrhp? bom?
Old Apr 27, 2005 | 08:17 PM
  #18
THEBOM's Avatar
THEBOM Racing. If it don't scare you a little, it's not going fast enough !!!
I have never just swaped a 11.5 to 14.o with out doing other mods too.
The new 14 to 1 is with in 3 grams of MrHp super light and is strong enough for NOS and durable enough for circle track. It's already clearanced for the high lift cams and big valves. If you want to lower the compession just put another base gasket on. It should have you in the 12.? to 1 range.
Looks like we have a Winner!!!!
Were is that brown truck when you need it. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 27, 2005 | 11:16 PM
  #19
MrMeaner's Avatar
Good info
Old Apr 28, 2005 | 02:01 AM
  #20
Doctorturbo's Avatar
GOT BOOST!
What is the best 14:1 piston?
Depends on what you are going to do with it. If you are just N/A with no juice then the lightest piston you can find would be the ticket.
If your going to put juice to it then you are going to have to find a piston that has a good thick crown and maybe put the ring package down a bit to shield the rings from the heat. You will loose some RPM by doing this but better that than have a "religious" piston or turn your rings inside out.
