How much grease should i put in the rear axle 650ds-04
Old Apr 17, 2005 | 12:52 PM
Andreas's Avatar
Default How much grease should i put in the rear axle 650ds-04
HI
I had a recall on my baja 650 x -04 but i live in sweden and the garanti doesnt apply here. so a took it apart and i have 2 questions.
How much grease should i put in the rear axle should i fill it up or only grease were the bearings are??
and what type of grease do you recomend?
/Andreas
Old Apr 17, 2005 | 03:59 PM
mudnuri's Avatar
I used heavy wheel bearing grease. Or the kind you would use to grease the front end on your car. After packing the bearing full of grease, I put a little bit in the carrier.
Welcome to the site.
Old Apr 17, 2005 | 10:14 PM
atvaddict01's Avatar
I used a marine grease.I packed the bearings by hand,put grease on the races then i put in the seal.
After the seal is in i put in a generous amount of grease behind it.
mywifesquad
8
Sep 21, 2015 08:20 AM
rawbdiggity
Sep 7, 2015 12:05 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
snowolson
Aug 31, 2015 03:51 PM
DeFox500
Aug 14, 2015 05:59 PM
