ds bogging
Old May 26, 2005 | 04:53 PM
boostin's Avatar
Default ds bogging
just changed the oil for the first time and the plugs also. cleaned the air filter also. From idle if i hit the gas quickly is bogs for a second and the revs up. If i do it slowly then no problem. whats the problem??
Old May 26, 2005 | 05:04 PM
Camds650's Avatar
Default ds bogging
IMO it sounds like the pilot screw is the problem, see the link below it should help (or you got a bad spark plug)
pilot screw
Old May 26, 2005 | 11:44 PM
NickDS650's Avatar
Default ds bogging
do you have the stock carb or the TM45?
Old Jun 3, 2005 | 12:06 PM
boostin's Avatar
Default ds bogging
the tm45
Old Jun 3, 2005 | 03:25 PM
650VIPER's Avatar
Default ds bogging
If you have the pump hooked up, adjust it back a little. Mine did the same thing and was pushing to much fuel. If you dont then I would guess your pilots a little to lean.
hueby
Nov 6, 2015 11:34 AM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
Sassinm1
Sep 30, 2015 04:23 AM
essonlaker
Sep 10, 2015 01:12 PM
spark1051
Utility ATVs
Sep 4, 2015 07:58 PM
