another valve question.
Old Jun 4, 2005 | 06:07 PM
H's Avatar
H
Default another valve question.
can the valves be adjusted with the head out of the bike. I have shim unders and it looks like it would be easier to do that way so I don't have to keep messing with the chain. Oh, I'm putting rings on my piston and new cams in which is why the heads off already. Thanks.
Old Jun 4, 2005 | 06:08 PM
CountryJoeGlass's Avatar
Yes you can.
Old Jun 4, 2005 | 06:11 PM
H's Avatar
H
Cool!! Thanks. That should make the job a little easier.
Old Jun 5, 2005 | 10:26 AM
omahapredator's Avatar
H should be fine just need the cam support torqued to spec when checking but i'm sure you know this...you MIGHT get a little tighter reading in the far valves (furthest from cam sprocket) without the cam chain installed...JMO
Scooter's Shop
23
Oct 22, 2015 07:04 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
