Dealer lied about recall... What to do?
Old Jun 9, 2005 | 04:52 PM
jackass650's Avatar
Default Dealer lied about recall... What to do?
mine used to make a popping sound when i rocked it back and forth, after I ordered new swingarm bushings 56.00 dollars it ended up that my swinarm bolt was loose, I tightened it to specs and everything is good now, you have a torque wrench handy check the nuts to see it they are tight to spec just my .02
Old Jun 9, 2005 | 05:54 PM
RacinJason's Avatar
Just be the better person...call down there talk to the service mngr...in a cool calm tone tell him whats up and then rather than demanding something ask if he has any suggestions and what the best way to resolve the issue would be for him...make it about how he wants to do things and not what you need and you may find him easier to deal with
BRAAAAP
Old Jun 9, 2005 | 07:34 PM
tinydapimp's Avatar
Where do you get the torque specs? my swing arm is making the same noise and I need to try to tighten the swing arm bolt but need the torque specs.
Thanks, Scott
Old Jun 9, 2005 | 08:23 PM
blue250r's Avatar
definetly check the bolt is tight , mine was loose, just back off the outer lock nut and pull up the inner nut a decent amount of force on a stock size ratchet should do, then lock up the outer nut again.
as for the mechanic saying that axel bearings failing could effect swing arm bearings [img]i/expressions/face-icon-small-shocked.gif[/img], he is one of two things , idiot or liar
Old Jun 9, 2005 | 08:49 PM
  #15
jackass650's Avatar
take the outside nut off torque the inner nut to 74 ftlbs then back it off a quarter turn checj to see if the swingarm moves freely then apply blue locktite 243 to the threads then torque the outer nut to 74 ftlbs and call it good
Old Jun 9, 2005 | 11:48 PM
  #16
JMann2380's Avatar
Well guys that is exactly what it was, the nut was loose on the swingarm pivot bolt. He still completely disassembled everything, greased it, checked it, and got it back to me today, so I am ok with that. When I brought up the recall, their excuse was that before they can sell the bike they have to put the vin into Bomb's computer system and it will say if it had any outstanding recalls, they say that none showed up. So its a he said, she said and since I would rather stay on the good side of my closest dealer I didn't get into a pissing match. It is finally fixed and let's hope that I don't see them for a while.
I NEED to ride... silver lake here I come....
Old Jun 10, 2005 | 12:07 AM
  #17
jackass650's Avatar
cool jman thanks for letting us know you got it fixed, did he grease it too when he was working on it?
ultangler
Nov 30, 2024 01:35 AM
Customer Service #1
May 15, 2020 08:46 AM
Johnny Mac
Aug 15, 2019 03:13 PM
Sw00p
Sep 24, 2015 02:50 PM
Elkaholic
Sep 6, 2015 02:44 PM
