radiator shrouds for ds 650
Old Oct 5, 2005 | 03:43 PM
ILivSD's Avatar
Default radiator shrouds for ds 650
FatHolly,
Did you also go with the On Dunes Hi Perf H20 flow kit ?
It would seem that should help a lot with the fan / heat issue.
Old Oct 5, 2005 | 05:29 PM
FatHolly's Avatar
Since I already had to replace the radiator I was hoping that would take care of any issues. If it does not I will be looking into the ODP water pump... and if that doesn't work I might be forced to loose a few pounds! That is the absolute last resort, however.
Old Oct 5, 2005 | 11:52 PM
Sunman's Avatar
Hey FatHally I to need a new radiator, I had a slight mishap and my knee caved in my stock one,YES it did leave a mark!!!!! So now I need a new one. Who is PWR? Did it mount up nicely?
Old Oct 6, 2005 | 11:08 AM
FatHolly's Avatar
Mounted up perfectly. You have to take off the steering stem, the oil tank, and one of the coils. It helps to have two people. One on each side to help push/pull it into place, and move any wires. Fit and finish is as good as any high quality hot rod radiator. I found mine on ebay.
Sorry about the thread jacking.
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
panicmanic
Sep 28, 2015 12:59 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
Logan Collins
Sep 5, 2015 08:03 PM
