How expensive will this fix be?
Old Jun 21, 2005 | 12:22 PM
BigJon's Avatar
Default How expensive will this fix be?
Was out at Pismo and let our babysitter ride around on my wifes 2001 DS.
Anyway, I think the clutch is now fried.....
You can put it into gear and watch the clutch actuator pull all the way back but when you let
it out, it doesnt go anywhere and the engine still runs.
What all is invoved and how much do you think it'll cost me?
Old Jun 21, 2005 | 12:56 PM
BlackHawk's Avatar
I don't think it is a huge job - not as quick as an oil change but not as bad as pulling the engine. You'll drain the oil, put the quad on it's side, then loosen a bunch of nuts and go to town. (You had better get instructions from the manual or someone who has done it though!) Now would be a GREAT time to get the heavier clutch springs if you have been considering them - though you said this was your wifes ATV so perhaps not.
I think clutch maintenance is considered slightly more than routine maintenance as for cost - the clutch that Mr. HP recomended to me was like $150 (I think it was the barnett) however the stocker is less, perhaps closer to $75 in parts. If your quad has a lot of hours on it then the clutch was probably ready to go anyway, and the babysitter just 'helped' it along.
Old Jun 21, 2005 | 09:04 PM
JMAC650's Avatar
Stock clutch with ron woods 60% springs cost me around $200
Old Jun 21, 2005 | 09:29 PM
650VIPER's Avatar
I dont think a clutch can go bad that quick, unless she was hammering it hard. Are you sure it's returning all the way? If so then it must be. Did you have trouble with it before?
Old Jun 21, 2005 | 09:34 PM
AZDUNERAT's Avatar
This may sound funny but make sure the lock nut that holds the sprocket is still on. I had it fall off on my warrior and it did the same thing. So I went out and bought a new clutch for the bike. Installed it but still had the same problem. Lo and behold when I checked to see if the sproket was stripped I saw that nut had come off. $4.35 to fix the problem, $115 for a new clutch I didnt need!
Aaron
Old Jun 23, 2005 | 02:50 AM
Sandaholic's Avatar
AZDUNERAT brings up a good point. A few trips ago while I was at Pismo my friends raptor made this horrible grinding noise under acceleration, of course I thought it was the raptors infamous transmission or clutch. It turned out to be his counter sprocket had no teeth left! Cheap and easy fix.
If factory plates and fibers along with RWR springs cost $200 then it may be cheaper and have better results with the barnett 9 disk system [img]i/expressions/face-icon-small-confused.gif[/img]
Old Jun 23, 2005 | 03:17 AM
DuneMe's Avatar
You may be able to find the parts from others on the forums [img]i/expressions/face-icon-small-wink.gif[/img]
Old Jun 23, 2005 | 12:44 PM
DSSleuth's Avatar
sounds like the actuator pin/rod. This part controls clutch going in and out. Pull the clutch cvoer and that will tell you. If it is just the pin, around$50.
Old Jun 23, 2005 | 10:31 PM
atvaddict01's Avatar
Just ordered, 150 for barnett kit and 2.50 for gaskett, from hpr.
Old Jun 23, 2005 | 11:54 PM
OregonDunePatrol's Avatar
What Gary said, the Rack Actuator - Been there.. right Gary?
