ds carb problems?
Old Aug 17, 2005 | 08:19 PM
bootleg's Avatar
Default ds carb problems?
THe sparks are dry cleaned the fuel tank.checked the bowl for fuel all this happenned after i changed the oil and filter.
Old Aug 17, 2005 | 08:40 PM
Scatterbrain's Avatar
I dont see how it can be related to oil and filter change. are you getting spark? No wet plugs. Does your battery have a full charge? Have you checked to see if you getting fuel to the carb. I just noticed in your first post you said you cleaned the "carbs" was that a typo or are you running dual carbs.?
Old Aug 17, 2005 | 09:13 PM
2BIG2BFAST's Avatar
Wait a minute i thought you said you cleaned the carbs. What you need to do is put it against the garage wall put it in 2, no im just kidding pull the choke and keep turning it over then pull the plug out and see if it is wet. you have to start somewhere. if you have spark and you have gas your bike should run.
Old Aug 17, 2005 | 09:39 PM
LMAO, Yep gotta start somewhere. Just be thankful you dont have a tranny problem[img]i/expressions/face-icon-small-wink.gif[/img] Fuel +Spark = Fire Try the choke route and keep us posted.
Old Aug 18, 2005 | 11:12 AM
  #15
1FastDS650's Avatar
What about the fuel valve? I had one go bad on me it would only work on reserve. Are you getting gas to the carb?
Old Aug 18, 2005 | 08:49 PM
  #16
bootleg's Avatar
I'm getting gas to the carb and i'm getting spark.I can't figure it out.After about 15 minutes of trying and throttling the whole time it starts sometimes.
anyone have the carb diagram i had a buddy look at it for me and i'm afraid he may have put something back together wrong thanx again guys.2001 DS
Old Aug 18, 2005 | 09:01 PM
  #17
pm me your e-mail
Old Aug 18, 2005 | 09:06 PM
  #18
2BIG2BFAST's Avatar
you are getting gas to the carb but are you getting gas to your plugs choking it and turning it over for 3 to 4 seconds your plugs should be getting gas. heres what you do turn the kill switch on that way it wont start pull your choke and turn it over for 4 or 5 seconds, pull the plugs and see if they are wet, you said you had spark but was it a consistent blue spark or was it reddish?
Old Aug 18, 2005 | 09:18 PM
  #19
Check your email Bootleg
Old Aug 18, 2005 | 09:32 PM
  #20
2big, could it have somthin to do with the needle maybe. Im runnin out of Ideas. Bootleg, what position is the needle in?
