10lbs = 1hp??
Old Sep 9, 2005 | 07:49 PM
bigbird650's Avatar
Default 10lbs = 1hp??
was reading this in the post "another ds" so is this true--and if so man im going on a diet to!!
Old Sep 9, 2005 | 11:27 PM
650VIPER's Avatar
Roughly yes.
Old Sep 10, 2005 | 04:12 AM
boogeyman3's Avatar
Well than if thats the case ive already gained about 4 hp! yea!!![img]i/expressions/face-icon-small-happy.gif[/img]
Old Sep 10, 2005 | 03:31 PM
Sandaholic's Avatar
If I understand it correctly, it does matter where the weight is being removed. Removing 5 lbs. of rotation weight such as tires, axles, chains, sprockets, etc will have a greater effect then removing 5 lbs. of weight that is bolted to the frame.
Old Sep 10, 2005 | 05:22 PM
DustinMinnesota's Avatar
Exactley rotating weight has more effect than static weight. Static weight causes the machine to fight friction where rotating requires more power to make inertia.
Old Sep 10, 2005 | 05:42 PM
DaBomb650's Avatar
What about weight SITTING on the frame..[img]i/expressions/face-icon-small-happy.gif[/img] I could gain 60HP if I wanted and STILL not be called thin!!
Seriously, I have heard the same thing. Of course it would not sho up on the Dyno. It really would be the HP "equivalent" while you are racing, duneing....etc. Now the rotating mass theory, that might show up on the dyno. Not sure. It would be interesting to see some test both ways.
Old Sep 10, 2005 | 05:45 PM
choosetolose04's Avatar
Rotating mass will show up on the dyno....[img]i/expressions/face-icon-small-wink.gif[/img]
Old Sep 11, 2005 | 12:01 AM
TheChosenOne's Avatar
1 lb of rotating weight is equivelent to 7 lbs of "dead" weight elsewhere on the quad. If the machine runs say a 4.60, it would take approx 1 more HP to achieve that same time if 10 lbs were added to the machine.
At least this is my understanding.
Loss of rotating mass will mean less torque/HP needed to move the mass in the same amount of time. You will not see as much of an increase in the peak HP numbers on a dyno as you will the HP being achieved much sooner.....There should yes be a slight peak number increase as well, at the wheels if the weight savings were done after the crank, and all over of it were done internally of the engine.
I may very easily be wrong, so if you have any different vews, please correct me.
01sportsmna500
Apr 10, 2012 07:46 PM
xr650
Dec 19, 2009 12:48 PM
upongame
Apr 11, 2009 04:59 AM
Jwb
May 31, 2008 01:49 AM
ATVHades
Oct 25, 2006 07:16 PM
