Snorkel tube bracket...where?
Old Sep 28, 2005 | 07:43 PM
SCOUNDREL's Avatar
Default Snorkel tube bracket...where?
I'm goint to be taking off my Airbox and was looking for a snorkel tube bracket to hole the air filter up.
Does anyone have any recommendations?....
Old Sep 28, 2005 | 08:06 PM
Scatterbrain's Avatar
I seen someone here made one that mounted to the frame. Myself I used a big zip tie, Works great, easy to replace. Makes getting the snorkle off for any carb work a snap. Plus It made to where I can scoot the filter and snorkle over to make enough room to hide my bottle [img]i/expressions/face-icon-small-happy.gif[/img]
Old Sep 28, 2005 | 08:38 PM
Sandaholic's Avatar
I made one out of aluminum, worked really well. I think I have some pictures of it on my web site in the technical section.
Old Sep 28, 2005 | 08:51 PM
SLC650's Avatar
Scoundrel pm me with your e-mail I think I have a hook up you could use for one[img]i/expressions/face-icon-small-wink.gif[/img]
Old Sep 28, 2005 | 10:52 PM
JMAC650's Avatar
Made mine out of alum. Had a fab shop cut me a piece and put a 90 degree bend in it. Then drill a 4 1/4" hole for the snorkle tube. I drilled and slotted some holes and bolted it to the upper front bolt holes in the rear fender. Worked perfect. Also mounted a tab for the breather tube and breather filter.
Old Sep 29, 2005 | 09:17 AM
Bellracing2's Avatar
Take a stock airbox and cut the sides and back out and leave enough so its still strong , and has a rectifier mount .
Old Sep 29, 2005 | 11:00 AM
ILivSD's Avatar
Hi there SCOUNDREL,
I kind of looked around for one but ended up picking up a piece of polished Diamond plate cut and trimmed it to size, drilled the needed holes to hold it on securely to the frame.
It looks pretty good & matches the Diamond plate battery support cover I made and does the job pretty nicely.
Total cost .... 10 bucks.... 2.00 for the diamond plate and 8.00 for the beer.
Enhhh gave me some thing to do.
Old Sep 29, 2005 | 07:37 PM
SCOUNDREL's Avatar
I don't like jury rigging things....I prefer the professional look. However, I can see where in your case it's a good fit...
SLC650 I sent you a PM....
Old Sep 29, 2005 | 08:43 PM
Im not a fan of jury rigging either but there was no way to get any sort of bracket in there with the bottle under there, Eventually I will probably move the bottle up front and put a bracket on there but its just too much fun having it in stealth mode.
Old Sep 30, 2005 | 02:53 AM
tombomb's Avatar
I like enexpensive so I just took a 2 inch hole saw and put as many holes as I could without jepordizing the integrity of the box , dump the lid and took a propane tourch to melt all the curly cues created by the hole saw and ta - da , most of the airbox is gone and the rectifer still has a home. Quick and fast gradifacation.
ReconBayou
Oct 31, 2022 05:37 PM
Customer Service #1
May 15, 2020 08:46 AM
CosmoM
Sep 21, 2015 04:57 PM
Steeldon
Sep 9, 2015 09:38 AM
Ean
Aug 20, 2015 07:13 AM
