Lost another CDI.
Old 10-11-2005, 11:24 PM
VEGAS650's Avatar
Default Lost another CDI.
Ok, I put the stock ignition(cdi and coils) back on.
I still have the "BAD" rectifier on.
Still no spark to the plugs.
Will the rectifier do this, or is there something else?[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old 10-11-2005, 11:33 PM
OregonDunePatrol's Avatar
The only thing I can think of besides the rectifier is the connection to the ignition. Check your connections to make sure. As far as the Rectifier being the culprit, who knows for sure? I know those are all bad anyways, might as well get it replaced with a good one.
Old 10-12-2005, 07:11 PM
VEGAS650's Avatar
Spoke to Majorecho today.
He says he had basicly the same problem and ended up having to change the trigger coil.
Hopefully this is it, then MAYBE my cdi is still OK.
Old 10-13-2005, 08:36 PM
VEGAS650's Avatar
It ain't the rectifier. Got to get a trigger coil.
  #15
Old 10-14-2005, 01:31 AM
budtbaar's Avatar
al !! I'm feelin for ya!! You built,,, a !!! bout the nicest bike around hope you figure it out!!
p.s. NO Dumont Sat. My son has homecoming we're going Sun. EARILY!!
  #16
Old 10-14-2005, 12:11 PM
Eaglecollector's Avatar
Do you have one on the way? If not that guy parting out the DS on Ebay might have one
  #17
Old 10-14-2005, 01:42 PM
VEGAS650's Avatar
He's selling the engine as a whole unit.
waiting for Gary to come back this afternoon.
  #18
Old 10-14-2005, 02:28 PM
BigJon's Avatar
Is rectifier the same as voltage regulator? If so mine was putting out 20 instead of 13 and was causing the engine to sputter.
It would idle fine but as soon as you throttled it it would sputter.
  #19
Old 10-14-2005, 02:47 PM
DaBomb650's Avatar
VEGAS650,
Are you getting voltage to the coils? One side should be battery votage with the ingnition on and in the thumb switch on.
  #20
Old 10-14-2005, 09:16 PM
VEGAS650's Avatar
Originally posted by: DaBomb650
VEGAS650,
When Larry and I checked that at Dumont(wiyh the MSD) we were not getting any voltage to the coil.
Assuming we checked it properly.
Neither of us know jack about elec.
Quick Reply: Lost another CDI.
