Change water Pump ?
Old Oct 12, 2005 | 10:56 AM
ILivSD's Avatar
Default Change water Pump ?
Hey there,
Just curious has any one out there change out there water PUMP ?
As I just got my On Dunes Hi Output unit and after breaking the seal can't seem to find out how to remove the drive impeller / shaft ? I have the manual and CD but was curious if its a quick job or a real 12pack of beer and weekend type upgrade ? as I am headed out to the desert Friday.
Thanks in advanced like my Procomm CDI.... [img]i/expressions/face-icon-small-confused.gif[/img]
Old Oct 12, 2005 | 11:15 AM
OregonDunePatrol's Avatar
You'll need to remove the stock pump cover, & stock clutch cover. The stock impeller & shaft will come right out with the clutch cover. Slide the black gear off of the back side of the shaft and remove the shaft pin. Then do the reverse with your other stuff.
Old Oct 12, 2005 | 11:26 AM
ILivSD's Avatar
Ahhhhhh Thanks Oregon,
Curious will I need to purchase any gaskets to do this ?
That works out pretty well as I need to crack the case any way to put in the heaver clutch springs ?
Old Oct 12, 2005 | 11:33 AM
The clutch cover gasket doesn't always need to be replaced everytime you open the clutch cover. But, I always like to have one on hand in case I need another one.
Since the clutch is exposed, you can replace the springs if you want - its easy access since its right there.
Old Oct 12, 2005 | 11:56 AM
ILivSD's Avatar
Cool Thanks ...
I am going to be busy ... : - )
Curious where can I get that gasket at the Dealer ?
Old Oct 12, 2005 | 12:00 PM
Um ... I wish I could say .... [img]i/expressions/face-icon-small-wink.gif[/img]
Old Oct 12, 2005 | 12:08 PM
DaBomb650's Avatar
IlivSD,
You are aware of the problems people have had with the clutch actuating gears with the stiffer clutch springs, right?
BTW - I have done my water pumps as well, it's easy. Make sure you use a torque wrench on the side cover, especially is you are able to save the old gasket.
When you get the waterpump cover off, check it to see if the impeller was rubbing the cover, mine was, see my page for pictures. I will be interested to see if it was.
Old Oct 12, 2005 | 12:13 PM
Originally posted by: clshortt
IlivSD,
clshortt,
Im curious as to why your stock impeller was rubbing on your stock pump cover? Worn shaft?
Old Oct 12, 2005 | 12:14 PM
Tpsycho's Avatar
My Bomb Busa is done now and WOW what a rush this thing is scary fast. I love it
Just put a barnett 9 disc clutch in mine but have not riden it yet.
clshortt What problems have people had with the heavy springs ?
Old Oct 12, 2005 | 12:15 PM
I had problems with my Rack Actuator shaft with the PAMI springs - but that was with the 2000 model - havent the shafts been upgraded? I havent heard a ton on the other springs.
