antifreeze in gas tank
Old 10-31-2005, 07:28 PM
xr650's Avatar
Default antifreeze in gas tank
was it high octane anti freeze or regular,cause I know my ds likes the high octane,was the screwdriver a phillips or standard tip?
Old 10-31-2005, 07:41 PM
1of4Horsemen's Avatar
Pale Rider
With my goldfish shorts swimmin' around my toes.
C'mon fellas the answer is quite obvious. It's the High Flow Oscillator. It's right next to the Unobtainium Deflector. Becareful when you take it off don't lose any parts. Just a fore warning you'll need a bolt stretcher to put it back on.
Old 10-31-2005, 07:51 PM
BioWare's Avatar
Toxic Ryder
I know the boy's in the here can be alittle mean, But even I'am at lost for words, I don't think any body has ever done that before, how did you mistake that for the radator. How long have you had the atv. From your post you lool like a new commer....But i'm sorry.. The only thing I can think of to do would be to take the motor apart and clean it all out.. Or if you can get the atv to start I would buy a ton of oil run it drain it, run it, drain it, run it, drain it....over and over agian...
Good luck you'll need it...just don't get discouraged keep at it.
Old 10-31-2005, 08:33 PM
OregonDunePatrol's Avatar
Its April Fools in October! Oh, and dont forget to adjust the Flux capacitor. Here is a picture to help you locate it. It's located in the just above the chriogenic tank suspended by two bands of transparent aluminum.
  #15
Old 10-31-2005, 10:07 PM
yamahawarriormods's Avatar
this is way too funny if you have not curled up in a ball yet....definetly get a new plug (spark plug) did you start it after you put coolant in the gas tank definetly drain the carb i would do this a couple times
  #16
Old 10-31-2005, 10:21 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
time for a new motor lol there's no way you're getting the crap u put int othat motor out again.. you need pretty much anything fro mthe gas cap to the end cap on the slipon needs replaces/rebuilt and cleaned
  #17
Old 11-01-2005, 12:38 AM
sandbomber's Avatar
Kieshaa could I have 1 bottle of those pills also[img]i/expressions/face-icon-small-happy.gif[/img]
  #18
Old 11-01-2005, 01:05 AM
Glenn,
Be carefull man, that bottle has a hole, and you never know what else she put in there!
  #19
Old 11-01-2005, 01:21 AM
sandbomber's Avatar
Right now I will try anything Mark LOL
  #20
Old 11-02-2005, 12:48 AM
cliffinAZ's Avatar
Sounds like your dirt intake valve is clean. You need suck in some dirt. Mmmmhmmmm.
Quick Reply: antifreeze in gas tank
