Intake Porting revisited one more time
#31
the stock carb is 42mm, if you change to a larger carb like the 45's and 48's so many of us run, you absolutely must port the intake to match, otherwise the larger carb is moot.
far as stock carb goes, a ported intake is debatable, but its a must with a larger carb.
#32
yeah for max topend power at the expense of velocity and throttle response.If someone is gonna run a big carb,chnces are they are going after topend so they may as well port the intake.Im ol skool i only port things when they are going to be beneficial to what im trying to do.I dont just "hog" things out cuz i think there are gains.Im all about maintaining velocity which helps volumetric effeciency and throttle response than all out flow.
#33
blah blah blah..you sound boring--but thats your choice---it was for fun...i just put my ds back together last night..i did omr modded carb,big gun cdi,air box mods,k&n filter, endcap and ported intake...OVER ALL---seams more snappy and definetely pulls longer and harder..so it was worth the extra 50$ to get it done to me..why not have any extra you can
#34
Which end cap did you end up with? That HPR one really lets it flow.
#38
On a side note, I would also add like I always have in the past, that accellerator pumps rock my woods filled world for log and rut hopping and nothing yanks the heavy front of a DS skyward like a good pumper carb. But sorry, this is a porting post, don't mean to run off on a tangent..
Mojave250A
Jul 11, 2015 10:38 AM
