Ds Overheat under extreme conditions....Normal??
Old 12-26-2005 | 03:25 PM
mudnuri's Avatar
Default Ds Overheat under extreme conditions....Normal??
I got my water temp gauge from jtatv. c om and mounted it to my dash. Lites up at night, too.
I wanted to go with AutoMeter Pro-Comp series to match the tach, but got this one for free. So I used it and it has worked good so far. ESR is another one that mounts right there on the hose between the thermostat and radiator. I hear they work but you can't see them like the one mounted to the dash.
Whatever happened, ds1? Everything working good? I live in South Florida and a lot of us use Engine Ice coolant and in-line coolers to help beat the heat. Seems to work okay.
  #22
Old 12-27-2005 | 02:46 PM
ds1's Avatar
ds1
Thanks guys I cleaned everything , Installed a supercooler, ESR temp Guage and i am running at 185...max temp is in 200 but only when I idle for a long time
I bought the esr guage in www.esr250.com
will post pic soon
MikeyBoyesq
09-22-2015 11:02 AM
01ssls1
09-22-2015 07:50 AM
Polaris Side by Sides
09-15-2015 04:33 AM
MikeyBoyesq
09-07-2015 11:44 PM
Quick Reply: Ds Overheat under extreme conditions....Normal??
