Stock bore stage 2 VS hpr 730 dyno
Old Dec 16, 2005 | 04:24 PM
  #51
BasicBajaX's Avatar
Keeps busy in the garage building one thing or another.
Default Stock bore stage 2 VS hpr 730 dyno
Originally posted by: choosetolose04
So, Is it safe to say that a all out race everything 730 kit should produce close to 80hp when properly tuned?
Back to it depends on who's dyno.
Old Dec 16, 2005 | 04:37 PM
  #52
THEBOM's Avatar
THEBOM Racing. If it don't scare you a little, it's not going fast enough !!!
95% of the drag motors I have running can be trail rode. No heating or lazyness on bottom.
10 degrees on the cams is right at 1 tooth. If your custom cutting cams,Why?? As far as the A1A2 cams go, I though they were off the self junk??? Not DRAG cams.
The pipe difference may have played a 3-5hp gain over the RW mod pipe. But the 730cc should have easyly made the difference over 650 with its custom cams.
BigDaddy, don't believe everything you read on different web sites!!!!
Old Dec 16, 2005 | 04:39 PM
  #53
BasicBajaX's Avatar
I think its more important as to how long you can stay at 80hp or whatever hp on whoevers dyno. Less shifts would seem better than peaky hp numbers
Old Dec 16, 2005 | 04:42 PM
  #54
ANNIHILATER's Avatar
No Mercy Racing! Got NOS?
Geat point Jeff. I didnt know the a1a2 were drag cams. My motor is no where near drag. Its not even set up for regular GAS... Its set up for alky dynoed with GAS carb. Its only 180 psi for compression.
And I could trail this motor ALL day long, It runs cooler than mikes due to how rich I run the bottom end. I made 5 passes on the dyno and it didnt even get past 160 degrees. lol
Old Dec 16, 2005 | 04:44 PM
  #55
biggerisbetter's Avatar
Let's see....stock bore drag motor with drag pipe and drag cams VS big bore trail motor with small cams and in frame pipe. Basiclly making the same power. Now the way I see it Bigdaddy has drag bike power with a dune/trail motor. Sounds like the best of both worlds to me.
I had a drag motor all this time and didn't know it!![img]i/expressions/face-icon-small-shocked.gif[/img][img]i/expressions/face-icon-small-confused.gif[/img] Mario.... I should have charged you TRIPLE!!! LMAO.
Bigger.
Old Dec 16, 2005 | 04:53 PM
  #56
THEBOM's Avatar
Bigger.
[img]i/expressions/face-icon-small-smile.gif[/img] LOL
Old Dec 16, 2005 | 04:58 PM
  #57
choosetolose04's Avatar
Bigger.
WOW! Im kinda feeling like a big league player since my "drag bolt-on motor" pulled 58hp on the dyno, [img]i/expressions/face-icon-small-shocked.gif[/img]
Old Dec 16, 2005 | 05:00 PM
  #58
OregonDunePatrol's Avatar
Originally posted by: BigDaddy331
This thread is going bad real quick.....
Before we start going into some sort of mob linching,
I know what MOB LINCHING feels like on this forum, this AINT IT! LOL [img]i/expressions/face-icon-small-wink.gif[/img]
Old Dec 16, 2005 | 05:12 PM
  #59
OK, OK, OK I will admit the secret of this so called drag motor I bought from Bigger for $1200... Well, Kyle told me that there was some special cow chit that was on the valve cover that was magical. lmfao
This little stock bore revs pretty fast for being on gas. BUT My old 730 made 10 more ft lb torq than this motor ON THE DIESLE DYNO with my modded RW pipe. FYI
Old Dec 16, 2005 | 05:16 PM
  #60
1BigDSRider's Avatar
Thats just wrong!!
