05x bogging 2nd gear
Old Jan 1, 2006 | 06:39 AM
2BIG2BFAST's Avatar
Default 05x bogging 2nd gear
I noticed my 05 x has a hesitation in second gear at low rpm. If you launch in second it takes off but kinda hesitates then all of a sudden it takes off like a rocket. if you take off in first and then shift to second its fine. seems like once it stutters for a second and then goes. i have not ever noticed it doing this. It cant be my weight because it does the same thing with my wife on it. she only weighs 125lbs. im a little confused. maybe i should take the no toil filter back off and put the stock one back on. thats the only change that has been made to it.
Old Jan 1, 2006 | 06:42 AM
choosetolose04's Avatar
The No-Toil will be flowing more air than the stock filter. You might need to rejet it again or maybe even move the clip on the carb. Just my 2 cents. [img]i/expressions/face-icon-small-wink.gif[/img]
Old Jan 3, 2006 | 02:54 PM
jusrlax's Avatar
Scott, you may want to try a 15 tooth front sprocket.
Old Jan 3, 2006 | 03:04 PM
650VIPER's Avatar
Yep, sure sounds like you need more power, or lower gearing, or less paddle.
Scatterbrain's Avatar
Stock pipe 2BIG? Did you mess with the jetting after putting the No-toil on? Get an open end cap or another pipe to get her to breath out the other end. Try a 175 main clip in the middle. I have an extra pipe and a HPR cap laying around. PM me
Old Jan 3, 2006 | 08:27 PM
2BIG2BFAST's Avatar
Come on guys you dont think i would adjust anything on there do ya[img]i/expressions/face-icon-small-smile.gif[/img] Thae bike has plenty of power, i guess you could not call it a bog, more of a hick up its a stutter than pow your gone. the x is stock except for changing the air filter .
Old Jan 3, 2006 | 09:24 PM
650VIPER's Avatar
Does it do it in neutral? punch it from idle, does it do it? If so....... LEAN!
scram5050
Aug 30, 2024 01:39 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Jazperman
Aug 7, 2016 08:12 PM
scram5050
Aug 19, 2015 02:19 AM
