DS 650 plastics
Old Jan 9, 2006 | 07:55 PM
Asmit's Avatar
Default DS 650 plastics
Recently my 03 DS650 baja was stolen and crashed. It had some damage but i just noticed that the plastics seemed to be bent up. My question is would it be the plastics bent or would it be supports or mounts or something else. Also would 05 DSX650 plastics/supports fit on my 03.
Old Jan 10, 2006 | 01:34 AM
HIMMEY's Avatar
I'm going to guess it's probably the supports. Reason being the plastics on the DS are very flexible(rolled mine once,flipped it once).Yes the 05 parts will fit the 03.
Old Jan 10, 2006 | 02:26 AM
BajaX04's Avatar
under the seat are 4 bolts for the rear fenders then down by the heel guards are 2 more on each side. Under the seat I doubt your supports are bent because that is your frame. By the heel guards yeas they can get messed up and tweak things around. The front nose piece really only has 2 bolt by the headlight, I am guessing this is your problem area.?? There are brackets you can order to replace you bent stuff, just go to your dealer its cheap. In 04 the headlight changed and it also came with a headlight plastic color ring. You will have to mod that for your 03. I dont remember the 03 having that dual bulb plastic headlight. Other than that headlight change (and you can convert over to the newer setup), any plasitc in any color will fit.
wendal
Aug 3, 2024 10:03 PM
Joe454
Nov 20, 2020 01:19 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
strokesb16b
2) Chassis problems..
Sep 15, 2015 09:19 PM
