Nitrous Question
Old Jan 13, 2006 | 09:14 PM
Downunder's Avatar
Default Nitrous Question
Happy New Year to everyone.
Would anyone know if 12.5 to 1 compression is too high for Nitrous and would a Ron Wood CDI be ok.
Any info would be appreciated.
thanks
Old Jan 13, 2006 | 09:35 PM
ANNIHILATER's Avatar
No Mercy Racing! Got NOS?
Should be fine... I ran nos with higher comp then that w/ RW cdi. You just need to run 110 octane or more. start out rich maybe 4 points apart on the nos/gas jets till you get the plug looking safe after a hard nos run... Is this the boondockers or wet system?
Old Jan 13, 2006 | 09:51 PM
Downunder's Avatar
My kit arrives on friday it is an NX kit which i believe is a wet system I'll be putting the bike straight on the dyno for tuning, would air fuel mixture be the same as running without the nitrous
Old Jan 13, 2006 | 10:18 PM
BigDaddy331's Avatar
I am running the HPR13:1 superlite piston with a RWR CDI. I run a 25 shot with now problem at all. I use 110 race fuel.
As far as jetting goes, you'll probably want to run a little rich until you get the system dead-nutts on. That will take a while and will change from day to day based on temp, Barometric Pressure, Altitude, bottle pressure etc. etc.
Go slow and tune rich before you tune lean.
Good luck.
BD
Old Jan 13, 2006 | 11:10 PM
Downunder's Avatar
sounds like rich is the in thing with nitrous, thanks for the info and Ill let you all know how I go.
Old Jan 14, 2006 | 11:47 AM
amd's Avatar
amd
Just dont let it get to rich. That is just as bad as being to lean. You can hurt things by being to rich also. Start with the recomended setting from NX then tune from there. My experiences with NX is they arent as conservative as NOS so tune a little at a time. Good Luck
Old Jan 18, 2006 | 03:17 AM
JET762's Avatar
Hi there i buddy i think you are a absolute freak and admire your courage but i think you need at leat 40hp shot cause i am currently using a 40 shot.
Old Jan 28, 2006 | 05:13 AM
DSexpress's Avatar
You will be just fine as long as your running the right octane fuel.
Old Jan 29, 2006 | 01:23 PM
amd's Avatar
amd
Jet thats a nice looking Rappy!
Old Jan 29, 2006 | 02:30 PM
1BigDSRider's Avatar
Your right about that!! Jet what dunes do you frequent??
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
