ds650 not running
Old Jan 19, 2006 | 11:00 PM
ThorMX902y's Avatar
Default ds650 not running
please help!!!
the other day i started my ds to take it out for a ride. while it was idleing with the choke ON it was fine nice steady idle. but when u turned the choke off it would idle for 5 seconds or soo then make a wierd tick noise n the carburator would shake. now wen i tryed to start it again yesterday it wont start and it backfires. but wen it backfires it dont only do it from the exhaust pipe it does it from the intake box to. it makes a wierd pop from the intake box n the whole cover wants to lift off. please help me get this thing running!
Old Jan 20, 2006 | 12:46 AM
Mrneg9's Avatar
You dont happen to be running an after market CDI box.If you are put the stock one back in and see if it corrects the problem. Be very careful. Everytime your bike backfires like you are talking about it is forcing your sparg clutch to go in the wrong direction. This will wipe it out after a couple of times. Costing $500.00+ in parts. Hope this helps, D
Old Jan 20, 2006 | 11:58 AM
Camds650's Avatar
Have you checked you valve setting?
Old Jan 20, 2006 | 04:49 PM
FatHolly's Avatar
Sounds like the valves need to be adjusted.
Old Jan 20, 2006 | 05:49 PM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
I was having an identical problem, everyone said check valves, did that, check air leaks, did that, fuel clogs, did that, pinched overflow hose, did that. Notta.[img]i/expressions/face-icon-small-mad.gif[/img]
Regulator/rectifier for $15 off of eBay---fixed it. Not a problem since. Well, clutch slippage, but that's not related...[img]i/expressions/face-icon-small-confused.gif[/img]
Search for "DS won't run. Help Please!" All of your answers are right there. Thanks guys![img]i/expressions/face-icon-small-happy.gif[/img]
Old Jan 20, 2006 | 05:54 PM
BioWare's Avatar
Toxic Ryder
My DS650 Does That every so often, I just replace the plugs, then its all better.
Old Jan 21, 2006 | 02:46 AM
ThorMX902y's Avatar
i found a high performance regulator
will it work the same?
Old Jan 22, 2006 | 03:45 AM
ThorMX902y's Avatar
FIXED IT
i had too much oil in it n it foul out my plugs so it wouldnt get good spark
only ended up costin $6.32 to fix
hugemoth
Jul 20, 2020 03:28 AM
Frisky2050
Apr 9, 2020 11:19 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
vernl
Jan 7, 2001 08:13 PM
