carb question again
so when its cold outside it automatically runs leaner? so when the temp gets around 70 or so it should run perfect? because right now its about 10-20
If you are useing the dj kit at that temp id be atleast a 185.
These guys have alot more experiance then me try the needle first.
Mine runs best in the middle groove.
But just make sure your not running lean on top.
One thing these guys have taught me is dont be afraid to change
your jets,to get it running right rather than OK.
Your still to far out even if it does get warmer you still will not be rich enough....i go from it being -20 to plus 30 C and my jetting is still perfect no sputters...altho it isnt spot on it still doesnt sputter so you still have to change the needle to the 3 third or so clip from the bottom to make it run right. Its easy takes about 5 min to do.
#15
