Frustrated....
Old Feb 6, 2006 | 04:33 PM
  #21
BajaX04's Avatar
Default Frustrated....
Sweet! X rated man boobies [img]i/expressions/face-icon-small-tongue.gif[/img]
Old Feb 6, 2006 | 04:47 PM
  #22
VEGAS650's Avatar
I had MANY electrical problems when I had my Pig. Especially after new powdercoating.
I agree with AZ.
I solved SOME of my problems by making sure I had a good ground.
Now if I could have solved all my issues![img]i/expressions/face-icon-small-sad.gif[/img]
I miss my Pig![img]i/expressions/face-icon-small-frown.gif[/img]
Old Feb 6, 2006 | 05:24 PM
  #23
DragonDJ11's Avatar
I agree with AZ.
Would you mind telling us what problems were solved by it???
Old Feb 6, 2006 | 05:39 PM
  #24
chirochris's Avatar
can someone take me by the hand and tell me how to check this grounding issue..
first find the battery, got it---then?????
Old Feb 7, 2006 | 04:39 PM
  #25
DragonDJ11's Avatar
Topper, any updates on this???
Old Feb 7, 2006 | 05:38 PM
  #26
Topper's Avatar
UP DATE: Bad rectifier, it wasn't doing it's job and caused the battrey to get over charged (Putting out 21.2 volts) Bombardier is replacing the rectifier and the battrey. I should be able to pick it up Friday evening or Saturday morning..... They also told me that if the rectifier has been bad all along that it could do all sorts of weird things like drain the battrey. I just thought I would throw that out there! [img]i/expressions/face-icon-small-wink.gif[/img]
Old Feb 7, 2006 | 05:51 PM
  #27
DragonDJ11's Avatar
21.2 volts may be a bit of an overkill [img]i/expressions/face-icon-small-happy.gif[/img]
Old Feb 7, 2006 | 06:46 PM
  #28
Entomber's Avatar
Topper I had a similar problem with my DS and when i took it to the dealer they told pretty much the same. Bad rectifier. Azsand and Bombsaint opened my eyes to my current build. I will check the ground connections very closely.
Now MrNeg needs to see what might be causing his problems.
VEGAS650
Ditch the YFZ and get back on the Pig [img]i/expressions/face-icon-small-wink.gif[/img]
Old Feb 7, 2006 | 07:34 PM
  #29
Topper's Avatar
Once I get it back I plan on going through the whole ground electrical problem. I also asked if this will be on record if I keep having the same issue. They told me it will all be on Bombardier paper work. Hopefully I won't have a problem any more.
Old Feb 7, 2006 | 07:41 PM
  #30
chirochris's Avatar
i hope this was your issue but i have a feeling it is not, just cause i had he same issues and it still happened after i replaced my reg..unless i had 2 reg go bad with in 6 months...i just recently replaced it again making it the 3rd..we will see
