ported intake
Old Feb 26, 2006 | 06:18 PM
ThorMX902y's Avatar
Default ported intake
wen u port ur intake wat else do u need to do to make it run right?
Old Feb 26, 2006 | 06:30 PM
Cammer's Avatar
Just completed my ported intake and all I have to say is WOW. Better throttle response an definitely more horsepower (seat of pants dyno)[img]i/expressions/face-icon-small-happy.gif[/img]
Needless to say it was time well spent. Took me about 3 hours all told and $17 for an inake on Ebay. I needed both by die grinder and the dremel. With all the great advice on this forum I was able to get great results. I really tried to remove material to straighten air flow, completly removed the hump and molding ridges and kept the vein to the carb. end. i also enlarged the opening in the rubber mount between intake and carb. All in all great, inexpensive mod even with stock carb! This mod will help bone stock to heavily modded set up.
Old Feb 26, 2006 | 08:34 PM
ThorMX902y's Avatar
do you have to change the jets?
Old Feb 26, 2006 | 08:46 PM
FatHolly's Avatar
Yes, you will be flowing more air.
Old Feb 26, 2006 | 10:34 PM
Cammer's Avatar
No I didn't but I think I was running a little rich.
Old Feb 26, 2006 | 11:34 PM
ThorMX902y's Avatar
wat jet should i run if i have the ported intake running wit the ondunes power tip n a k&n airfilter with precharger bag
Old Feb 27, 2006 | 02:23 PM
Cammer's Avatar
What is the altitude where you ride?
Old Feb 27, 2006 | 05:04 PM
ThorMX902y's Avatar
i think that i am about 149 feet above sea level and 21 meters
im not oo sure but im not good with stuff like that
Old Feb 28, 2006 | 02:22 PM
Cammer's Avatar
Bombardier seems to jet these a little rich from the factory. I would ride it first and see if it even needs to be re-jetted. Try a few runs with the airbox lid on then take it off. See when it runs better and that should answer whether you need a bigger jet or not.
franklyme
Oct 21, 2016 07:18 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
QuadRiders
Oct 22, 2015 04:13 PM
Sassinm1
Sep 30, 2015 04:23 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
