High Compression and Spark Plugs
Old Mar 3, 2006 | 12:03 AM
ERBEDS650's Avatar
Default High Compression and Spark Plugs
Do you change the Heat Range on your spark Plugs when you raise your compression, my LT 500 was useing heat range of 8 and now runs on a 9, the stock DS is a DR8
Old Mar 3, 2006 | 01:24 AM
DSNUT's Avatar
[img]i/expressions/face-icon-small-wink.gif[/img]
Old Mar 3, 2006 | 03:37 PM
Hightower's Avatar
I ran the dr8 for many years on 11.5:1 compression, and now I'm 14:1 and still running the dr8. actually I'm running the iridium dr8, but yes the same heat range.
Old Mar 3, 2006 | 08:17 PM
Scatterbrain's Avatar
Im at 13:1 and HPR recommended dr10. quite a bit cooler but Im also on the bottle.
Old Mar 3, 2006 | 08:34 PM
5X's Avatar
5X
DR 9 here 12.5:1 w/twenty shot
Old Mar 3, 2006 | 10:43 PM
MrMeaner's Avatar
HPR says a 9 with the 14/1
Old Mar 3, 2006 | 10:53 PM
DSNUT's Avatar
That is interesting. HPR sent me 10's with my 730 kit and I am 13:1. I wonder if conventional wisdom has changed with testing?
Old Mar 3, 2006 | 11:32 PM
Hightower's Avatar
I upped my octane to combat the added combustion heat you would expect from a higher compression. my coolant temp is now Lower running the 14:1 with 110 octane than it was running 11.5:1 on 93 octane. I pondered going up to the 9 heat range plug, but since I cannot see any additional heat elsewhere, I am assuming I am okay. I may be wrong, don't take my word for it, I am no expert. there really shouldn't be any adverse effect going to a dr9 anyway, except maybe in extreme winter cold, so if in doubt better safe than sorry. and who knows, come summer I may need to go to the dr9, and if so then I will.
there are thermocouples you can get in the size and shape of a plug's cush washer, to be mounted between the plug and the head for the purpose of measuring temps right at the plug as a direct result of combustion temp. if this testing has been utilized with the 14:1 and appropriate octane fuel, and the results indicated the need for a dr9, then that would be a definite change in conventional wisdom through extended modern testing. has anyone done this? the results would be interesting.
Old Mar 4, 2006 | 02:26 AM
2fun's Avatar
The color of the porcelin should tell you if you are too hot or too cold.
For my 250R, I went from 180 lbs compression and a BR8ES to 235 lbs of compression and a BR9ES. However, if you are running cooler, I see no reason to have to change your spark plug (unless you were running a LOT cooler).
Sjrpp
Jun 2, 2019 07:25 AM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
MNatv89
Jul 7, 2015 11:36 AM
D-Hagz
Jul 4, 2015 02:19 AM
